It is currently Tue Aug 12, 2025 6:18 am
Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Tue Jan 19, 2016 9:56 pm
Hesh wrote:
Just wondering here and not looking for replies but has anyone noticed things that we ourselves may have incorporated into our creations at one time or another that we won't or don't do now because we found a better way from what has been listed in this thread?
I have..... :roll: [headinwall] :D
One example that I did early on but will never do again.... is finish a guitar with the neck on.... Looks great and no problem until neck reset time... Then the finish at the joint has to be sliced open and there is more finish touch-up required to make it look perfect. When combined with a bolt-on system that was selected for it's ease of serviceability finishing a guitar with the neck on and the resulting extra effort required at neck reset/adjustment time it seems counter to making the joint serviceable with a bolt-on system.
Ah.... we live and learn.... :roll: :D
Hesh, I've always wondered about the Sons of Somogyi and the big man himself. They finish their guitars with necks attached so they get that seamless look between the back and bottom of the heal.... I've never seen their neck attach system, I do know they use a rather large headblock and with the added cutaway to 99% of what they build, coupled with a shorter scale length (most are 25" If I'm correct) I'm wondering if all the design features have brought them to believe their instruments will never need a neck reset.....?
Bruce & Matt Petros do the same....attaching the neck before finish that is.
That's a bunch of big name builders...... :?: :?:
These users thanked the author Rod True for the post: Hesh (Wed Jan 20, 2016 6:33 am)
PostPosted: Tue Jan 19, 2016 10:24 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I don't think these have been mentioned:
#1 Minimalist neck blocks with no slipper foot or extension under the fingerboard. Carrying the reinforcement for neck rotation forward towards a major brace or two really cuts down on the need for neck resets. (This requires a neck block with the grain oriented in line with the neck, or alternatively, a built-up neck block--built up with a waterproof, heat resistant glue, such as Titebond III, or resorcinol if you're doing a dovetail joint.)
#2 Thin fingerboards. These compound the issue of the tiny neck block, and impair playability on the higher frets.
These users thanked the author Eric Reid for the post: Hesh (Wed Jan 20, 2016 6:45 am)
PostPosted: Tue Jan 19, 2016 10:42 pm
Last Name: Farmer
City: Durango
State: CO
Had to fix one of these beauties yet Eric?
These users thanked the author david farmer for the post: Hesh (Wed Jan 20, 2016 6:45 am)
PostPosted: Tue Jan 19, 2016 10:46 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Alain Desforges wrote:
Well Dennis, from where I'm from, if I waited to brace when we have a perfect 50 RH, that would give me a window of about a whole week and half in late May. It's usually 80+RH in the Summer, and -20 to -30 (Celcius) in the winter with forced air heating. I run the A/C and the humidifiers respectively to try and maintain a nice stable RH, but unfortunately, I can't do much about the weather! ;)
Alain--controlling humidity while you're building is absolutely crucial. (That's easy for me to say. I live in a very forgiving climate.) Don't blame it on the weather. However you accomplish it, you have to control the humidity in your building area. That can be a closet with vapor barriers, insulation, and AC running full-time. If you build in high or very low humidity, your guitars will self-destruct. The problems won't be subtle. There's a long history of builders who tried to ignore this.
These users thanked the author Eric Reid for the post: Hesh (Wed Jan 20, 2016 6:44 am)
PostPosted: Tue Jan 19, 2016 10:50 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Ouch. No I can't say I have.
PostPosted: Tue Jan 19, 2016 11:44 pm
I just did. Guitar got dropped and the back separated where it was joined to the rim and I thought the head block. Whoops a champferd head block. Who's great idea was that?
These users thanked the author Terence Kennedy for the post: Hesh (Wed Jan 20, 2016 6:44 am)
PostPosted: Tue Jan 19, 2016 11:52 pm
Factory built guitars might suffer dryness a little better, but I find that hand made guitars tend to move more with RH swings.
And that begs the question, why do people brace in such high humidity? How many builders have ever gotten a guitar back with high humidity damage, as opposed to cracks from drying out?
I have. More than once. Actually more problems from owers over humidifying than under. A high output Oasis in the Soundhole and a couple of soap dishes in the case when they have a furnace humidifier and it's 40% in the house. I measured one case at 60% and I build at 40%.
Anyone else seen that.
These users thanked the author Terence Kennedy for the post: Hesh (Wed Jan 20, 2016 6:43 am)
PostPosted: Wed Jan 20, 2016 12:46 am
Last Name: Kincheloe
They use a permanently joined neck (glued and pinned mortise and tenon), so if it does ever need reset, it will be via the heel slip method. I do the same, but use a true integral neck rather than the M&T, because honestly that seems like the worst of both worlds... have to do the work of cutting and fitting the neck joint, but can't separate it later. Integral is much easier for me, which is one of the reasons I use it. Several other things I do, such as ultra-thin French polish finish, hide glue, and often no back binding, all make the heel slip procedure relatively painless.
I wrote a huge spiel on upper bout structure/neck resets here, which largely applies to the Somogyi style.
These users thanked the author DennisK for the post: Hesh (Wed Jan 20, 2016 6:42 am)
PostPosted: Wed Jan 20, 2016 6:40 am
Don't know Rod since I'm not a son of Somogyi if there is any effort to engineer less reliance on neck resets in the future. I've never heard that one before either.
Finish with the neck on was done in my case because the finisher that I used for those guitars, Tony Ferguson at least at that time preferred to finish with the necks on. And of course back then I didn't understand the considerations necessary for future serviceability either. Finishing with neck on and belaying neck resets are two different issues other than the later is more of a pain if the former was not considered first...:)
I've never heard anyone claim that their instruments are neck reset proof if you have that would be a very interesting discussion and perhaps start a thread on the topic? Thanks.
PostPosted: Wed Jan 20, 2016 7:48 am
And so do just about all the Asian manufactures -- mainly so that gap filler and and poor workmanship can be concealed. And many also spray after the bridge is attached as well, I don't think that's a good idea.
Perhaps this is a live and learn proposition regarding steel string guitars. Now with traditional classical's and steel string guitars with Spanish heel construction -- there is no choice.
Ken Cierp
These users thanked the author kencierp for the post: Hesh (Wed Jan 20, 2016 8:56 am)
PostPosted: Wed Jan 20, 2016 9:02 am
Here's another one: Only a drop of glue is needed to keep a well fitted nut in place.... IME major manufacturers understand this but smaller builders at times don't. If you fit the nut well it will even kind of sort of.... snap into place and the friction fit combined with that drop of an appropriate glue will get it done.
PostPosted: Wed Jan 20, 2016 7:27 pm
Last Name: Baley
City: Goleta
Zip/Postal Code: 93117
How about the practice of not including any mechanical attachment like bolts, screws, pins etc, to supplement the glue holding the bridge in place. Using only glue seems traditional and aesthetic but not the most structurally sound.
Any good reasons to use glue only (assuming the additional support still allows removal of required).
These users thanked the author Dave Baley for the post: Hesh (Thu Jan 21, 2016 6:19 am)
PostPosted: Wed Jan 20, 2016 11:50 pm
Last Name: Cox
I would vote bridge bolts at close to #1 on the list....
I have seen a LOT of guitars with bridges pulled off - and the bolts only maybe help slow down the speed at which it tears loose... They do nothing for the propensity to separate..... and when they do - they rip huge holes in the top.....
In my own analysis/evaluation - the bridge bolts are mostly not for structure, but rather for voicing (Notice how they never use big, wide washers - but rather longish heavy brass bolts and screws about 1" longer than needed)... They are a way to "Add some bass" to a massively overbuilt and ultra-treble balanced guitar by killing some of the trebles... Bridge bolts are probably the main reason that most "Budget" cedar topped guitars don't really sound that good....
My solution is to simply match the curve of the top to the bottom of the bridge and glue just like any other brace on the top.... Then - the wings aren't trying to pull themselves loose from the get-go....
These users thanked the author truckjohn for the post: Hesh (Thu Jan 21, 2016 6:24 am)
PostPosted: Thu Jan 21, 2016 6:23 am
Yes! Hey Dave. The goal is not just to hold the bridge on but the goal also includes creating a responsive guitar. Where the bridge is located is some of the most valuable real estate on the entire guitar and uber sensitive to changes in mass. Now it can go either way at times but adding mass in this critical area as nuts and bolts will do is not always a good thing. On a heavily built instrument it seems to matter less than a lightly built instrument in terms of responsiveness and there are not constants here, every guitar is different.
Nonetheless unneeded mass in this critical area is frowned upon in the trade. Besides HHG used as it wishes to be used will keep a bridge on for decades if the instrument is cared for. No bolts required. :D
PostPosted: Thu Jan 21, 2016 8:35 am
I seem to remember a post where it was mentioned that secondary bolts or pins do not prevent glue line failure. Perhaps I imagined that?
Let us not forget that Gibson actually did use "screw on" bridges on some models -- and they were made of lovely wood grain plastic! Hesh you must see those from time to time.
Ken Cierp
These users thanked the author kencierp for the post: Hesh (Thu Jan 21, 2016 12:31 pm)
PostPosted: Thu Jan 21, 2016 11:04 am
Hey Ken ... talk about contact patch! lol ... at least that's better than the onslaught of modern guitars I see in the shop with lifting bridges, where a thick poly top was sprayed, then glue was slathered in the bare bridge "pit" and a bridge then clamped (with no chamfer of course) so as to ensure that there is near zero wood-to-wood contact in the patch. The sheer characteristics of glue are universally well-known ... and well, let's just say that for water-based glues one needs to learn how emulsions work, and for epoxy and PU ... well ... blech (and their sheer characteristics are poor, as well)
Andy
These users thanked the author AndyB for the post: Hesh (Thu Jan 21, 2016 12:41 pm)
PostPosted: Thu Jan 21, 2016 11:52 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I'll add the general idea that....."The more expensive the wood, the better the guitar will sound"
Sure there are structural concerns with quarter sawn wood and even grain, and some of those grain figures are so gorgeous. But that's no guarantee of great tone.
These users thanked the author Quine for the post (total 2): Hesh (Thu Jan 21, 2016 12:41 pm) • rlrhett (Thu Jan 21, 2016 12:39 pm)
PostPosted: Thu Jan 21, 2016 12:39 pm
Hey Ken! Yep we see em frequently and Dave made a YouTube video of the pl*stic bridge replacement that gets tons of hits.
https://www.youtube.com/watch?v=HgkcA9ikHFQ
We also get calls monthly of folks who want to send these to us to do the replacement but we won't accept shipped in work but usually try to suggest someone in their area.
PostPosted: Thu Jan 21, 2016 1:11 pm
Last Name: Farmer
City: Durango
State: CO
Got one on the bench in front of me this very am Ken. Let's not forget the horror when combined w/ a Spruce plate. wow7-eyes
4 bolts wasn't enough. Maybe a 5th would do it.
These users thanked the author david farmer for the post: Hesh (Thu Jan 21, 2016 1:31 pm)
PostPosted: Thu Jan 21, 2016 1:32 pm
Sheesh David that looks almost good enough to be a G*bson......:) What were they thinking.....
Don't get me wrong I'm a fan of old G*bsons.... usually....:)
PostPosted: Thu Jan 21, 2016 3:00 pm
No doubt seeking superior tone!
Ken Cierp
These users thanked the author kencierp for the post: Hesh (Sun Jan 24, 2016 6:32 am)
PostPosted: Thu Jan 21, 2016 3:31 pm
City: Escondido
Zip/Postal Code: 92029
I don't even understand what I'm looking at here. Is the headblock chamfered and then a wedge is added to un-chamfer it? Why would anyone do that?
These users thanked the author rlrhett for the post: Hesh (Sun Jan 24, 2016 6:32 am)
PostPosted: Thu Jan 21, 2016 4:24 pm
Last Name: Farmer
City: Durango
State: CO
The wedge is the repair so I don't have to do it again the next week.
Maybe the chamfered block is a fusible link to prevent headstock breaks. :D
I would like to put some in a ziplock and send them to Nazerith w/ a note saying," I think you forgot these".
If I remember, 18* wedge w/25' dish sand on one side, in case anyone gets one.(and they will)
These users thanked the author david farmer for the post: Hesh (Sun Jan 24, 2016 6:33 am)
PostPosted: Sat Jan 23, 2016 9:01 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
First off, this is a fascinating thread. I am constantly wondering why some small builders make the choices they make. One lens through which to view those choices is the "that's what the customer wants" viewpoint. Another is the "sticking with traditional designs" viewpoint, which overlaps the customer desire aspect. The opposite is the "I want to set myself apart from the pack" viewpoint. These, and several others, are all valid considerations. How you come out on the specific choices can vary greatly, however.
Here is something that I, personally, see as a "don't try to follow the factories" decision for a small builder: finish material and application process. I see the factories having the upper hand on the application processes and the ability to handle dangerous finishing materials without issues. I think small builders should not be spraying nitro in their basement shops, for instance. Moreover, why try to emulate the aspects of factory guitars that were borne of the necessity of using mass production processes? You build guitars by hand; embrace the tinkerer aspect of that and use a finish material and process that a player can't normally buy on a factory guitar. To me, setting yourself apart from the Martins and Taylors, but in a good way, is pretty important. Otherwise, you are building wannabes. Just my opinion.
These users thanked the author doncaparker for the post (total 3): Hesh (Sun Jan 24, 2016 6:34 am) • DennisK (Sat Jan 23, 2016 1:33 pm) • Haans (Sat Jan 23, 2016 9:12 am)
Users browsing this forum: Glenn LaSalle, Ken Lewis and 38 guests
